Need Help with Hole on C2 - NCRS Discussion Boards
  • Michael M.
    • November 1, 2001
    • 411
    Hi, Can anyone tell me the original size of the hole above the front parking light for the bumper to bolt thru on a 65. Mine was filled in years ago and I can`t tell the original size. Thanks in advance!
  • Gene M.
    • April 1, 1985
    • 4233
    Re: Need Help with Hole on C2
    my white 67 conv. has just under 1" holes in the front fenders for the bumper bolts to go thru. the bolts are only 7/16" so i would suggest starting with a smaller hole and make it bigger if you need it. there is a slight raised rectangle pad that centers about the hole. many cars repaired in this area are sanded smooth eliminating the pads.
    • Mike G.
      • January 1, 1991
      • 418
      Mike: If you don't have the raised pad that Gene mentioned, there's a benefit to you--you can drill the hole wherever it needs to be.
      I suggest a 3/4" hole which will give you some adjustment room.
      The challenge is getting the front bumpers parallel to the ground and these outside bolt locations are key.
      • Michael M.
        • November 1, 2001
        • 411
        Thanks Nike and Gene, I will go with the 3/4 until I can fit the brackets later. Mike
