Pre-painted parts - NCRS Discussion Boards
Pre-painted parts
  • Steve L.
    • June 30, 2001
    • 763
    Pre-painted parts
    What do you do with pre-painted parts like A-arms, differential cross member, etc. that are supplied by the vendors. Do you use them as-is or do you apply a better paint such as DPLF90 over the paint. Perhaps strip the pre-paint and use DPLF90(seems like a lot of work.
    Steve L
    73 coupe since new
    Steve L
    73 coupe since new
    Capital Corvette Club
    Ottawa, Canada
    • 43250
    Re: Pre-painted parts
    Steve L
    73 coupe since new
    Steve-----
    You do one of the following:
    1) IF AVAILABLE and you wish to use your own paint, you request the supplying vendor to leave the parts UNPAINTED;
    2) Other than the above, you leave them painted as they are supplied.
    If you attempt to strip and re-paint assemblies, you'll usually end up with something that was better left the way it was received.
    If you overpaint, you'll end up with too thick-looking paint and you may end up with paint incompatibility problems.
