I have 1960 Corvette(270HP) with a correct replacement distributor that has the wrong date code. I lost one point for the date in judging. If I replace the tag with a reproduction tag with the correct date will I lose points for having a reproduction tag? Thanks for your input.
C-1 Distributor Tag
Tags: None
- Top
Re: C-1 Distributor Tag
Only if the reproduction tag differs in appearance from an original tag.I have 1960 Corvette(270HP) with a correct replacement distributor that has the wrong date code. I lost one point for the date in judging. If I replace the tag with a reproduction tag with the correct date will I lose points for having a reproduction tag? Thanks for your input.- Top
And there's some controversy whether they're supposed to be red or silver.- Top
