I have a '66 427-425 HP. car and have noticed (I've had the car about 6 months) that the upper bolt/nut that holds the idler arm (pass side of car) to the frame bracket is within an 1/8th in. from the rightside exhaust manifold. The front sparkplug half-round metal heat shield is touching the upper-control arm rear bolt/washer/bushing. Also, if you check the clearance at the bottom of the front crank pulley to the cross-frame there is only about 3/8" clearance which would be tight to change a belt.
It seems to me that the right side of the engine is low (maybe about 1/2 in.too low). I lifted the car and checked both motor mounts and they look new or reasonably new. They dont seem to be twisted or distorted out of shape. The right one does have some minor cracks but nothing serious. The car was frameoff about 7 years ago and engine was out, etc., and they look like they were replaced then. The frame mounts for the motor mounts look good - no twisting or distortion with original weld. Is there anything else I am missing??
