1963 Voltage Regulator - NCRS Discussion Boards
  • Randy R.
    • April 2, 2007
    • 39
    I have consulted the archives as well as the AIM and still cannot find a clear answer as to which P/N voltage regulator I need. My '63 was assmebled in late July (VIN#20654). Should I have a 1119512 or a 1119515 voltage regulator? Would a 1119512 dated 3F pass judging?
  • Rick A.
    • July 31, 2002
    • 2147
    Re: 1963 Voltage Regulator
    Randy,
    am at work, but will check my July 11 build date car when I get home
    Rick Aleshire
    2016 Ebony C7R Z06 "ROSA"
    • Harry S.
      • July 31, 2002
      • 5330
      Randy, I have an April 20th car, 133XX. I have a 515 dated 2L. I've been looking at this for some time and best I can determine is, either a 512 or a 515 is OK.
      • Michael H.
        • January 29, 2008
        • 7477
        Unrestored 63, #19,746 had/has a 512.
          My recollection is the '63 AIM only calls out the '512 regulator with the '64 AIM calling for the '515 regulator. If my memory is correct, then the change happened when designers were releasing drawings to support the next model year (1964) and those started 'dribbling' out in the April/May timeframe of the current model year.
          That would imply both of the parts ('512 and '515) would have been in house toward the end of 1963 production and may have been freely substituted based on what level of inventory was on-hand... Generally, if there's something 'hard' known about the transition of a given running change, it's discussed in the JG book.
          • Rick A.
            • July 31, 2002
            • 2147
            have 515, 3F on my 19367 Z06
            Rick Aleshire
            • Chuck G.
              • May 31, 1982
              • 2036
              I also have a 515 dated 3F on my 19496 (July built) convertible.
              Chuck
