A C1 original signal harness - NCRS Discussion Boards
  • Roy B.
    • February 1, 1975
    • 7044
    http://cgi.ebay.com/ebaymotors/53-55-Corvette-Directional-Signal-Switch-w-Wires-GM-NOS_W0QQcmdZViewItemQQcategoryZ140729QQihZ002QQite mZ120309386490QQrdZ1QQsspagenameZWDVW
    I posted trivia a while back about the C1 turn signal harness that the original's had a flat solid wire end connector and the replacement second design were split ends that can fall out of the main harness females .
    Now days you see and get the second design on e-bay or suppliers, but here is on e-bay the real original design if any one is interested.
  • Joseph R.
    • 94
    Re: A C1 original signal harness
    Would this work on a 59? Thanks, Joe.
      It should... The only difference I know was the running change sometime in '53-54 with the TS switch wires changing from cloth wrap to vinyl insulation.
      • Roy B.
        • February 1, 1975
        • 7044
        It will work on a 53 to 62 and many early Chevy's
        This one is the read deal NOT a second design or repro. best ROY
