Intake Manifold Plug - NCRS Discussion Boards
  • Joe C.
    • August 31, 1999
    • 4598
    The 3/8" NPT plug in midyear aluminum intakes for cars not equipped with power brakes has a square head. Does anybody have a car with an original plug installed? I'm interested in learning whether or not there are markings on the head, material that plug is made from, and anything else that might be important.
    Thanks in advance.
    Joe
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Intake Manifold Plug
    Originally posted by Joe Ciaravino (32899)
    The 1/2" NPT plug in midyear aluminum intakes for cars not equipped with power brakes has a square head. ..... I'm interested in learning whether or not there are markings on the head, material that plug is made from, and anything else that might be important. Joe
    Joe -- this is the original plug, either off a '64 '461' manifold around Dec '63 vintage; OR... (I can't remember and may have switched) off a L78 '963' manifold of Feb '65 cast. Bare steel with a touch of rust -- interesting feature is that 'tit' off-center on the head.
    • Stuart F.
      • August 31, 1996
      • 4676
      Looks more like a pimple to me.
      Where is this plug? Are we talking cast Iron manifolds only?
      Stu Fox
      • Wayne M.
        • March 1, 1980
        • 6414
        ...Where is this plug? Are we talking cast Iron manifolds only? Stu Fox
        Stu -- pic shows plug from an aluminum manifold, but I see '65 AIM shows square plug (UPC 6, Sheet C1) as part # 445673, (opt 9420756). These would be on the base engine (cast iron manifold). '65 P&A30 Gr 8.971 Pipe plugs; shows the first # as 3/8" Sq. Hd. Dryseal, Plain; the optional is described as 3/8" Sq. Hd. Dryseal, steel [both 3/8"-18].
        I also have a cast iron '65 BB manifold #3866948, cast late May, with a headless countersunk hex, but I kinda think this is not original.
        All these plugs are located on intake runner for cyl.# 8, forward of the distributor.
        • Dick W.
          • 10483
          Joe, Wayne, I have taken many of these engines apart over the years and never seen anything, that I thought could be original, with something other than the square plug
          Dick Whittington
          • Jeff S.
            • July 31, 1984
            • 384
            Joe
            The plug size/thread form on intake runner 5-8 should be 3/8-18NPT, not 1/2". The other three female pipe threads (temp sensor, bypass & heater hose nipple) are 1/2-14NPT. Perhaps the boss on your manifold was repaired oversize to accomodate the larger fitting?
            • Joe C.
              • August 31, 1999
              • 4598
              Thanks Wayne............just what I needed.
              • Joe C.
                • August 31, 1999
                • 4598
                Jeff,
                Duly noted and corrected above. Yes, the forward 3 coolant taps are 1/2" and the manifold vac tap is 3/8".
                  The plug in my 3872783 iron intake ('67 327/300) is exactly like the one in Wayne's photo above, but the "pimple" isn't as pronounced.
                  • Rick S.
                    • January 1, 2003
                    • 1203
                    On my 67 327/350, aluminum intake, it has a circled 7 on the top of the plug.
                    Rick
