L78 Oil Capacity - NCRS Discussion Boards
L78 Oil Capacity
  • Joel T.
    • April 30, 2005
    • 765
    L78 Oil Capacity
    Hi All;
    Can someone tell me what is the correct (CJ-4!!!) oil capacity is for the L78 motor?? I could not find this in the archive....
    Thanks!!
    Joel
    • 15706
    Re: L78 Oil Capacity
    Someone should confirm, but I believe all big blocks of the era take 6 quarts for an oil and filter change (Assuming that the OE cartidge type filter is still installed), and 5 quarts if the filter is not changed - same as the mechanical lifter C2 SBs with the "big" pan.
    • Joel T.
      • April 30, 2005
      • 765
      Duke;
      Thanks!
      Joel
      • Wayne M.
        • March 1, 1980
        • 6414
        Someone should confirm, but I believe all big blocks of the era take 6 quarts for an oil and filter change (Assuming that the OE cartidge type filter is still installed), and 5 quarts if the filter is not changed - same as the mechanical lifter C2 SBs with the "big" pan. Duke
        Duke -- Just checked a 1966 Chassis Service Manual (incl. Corvette, Chev and Chevelle) and it confirms what you've said for Corvette 427's (believe '65 396's used same oil pan) Interestingly, it shows 4qt. + 1 [filter]) for other '66 396's and 427's; Corvette is the only one with 5+1.
        • Stuart F.
          • August 31, 1996
          • 4676
          I take it there is no Power Steering consideration with the big blocks?
          Stu Fox
          • Wayne M.
            • March 1, 1980
            • 6414
            I take it there is no Power Steering consideration with the big blocks? Stu Fox
            Correct -- no interference with P/S linkage on large capacity BB Corvette oil pans. Not the case with steering dampers, though.
            There was an old Tech Service Bulletin about the first batch of L78's that had the damper, and there was a recall. Haven't seen that TSB for decades, and I'd like to check what I think I remember.
              • 43293
              Wayne----
              All 1965-74 Corvette big blocks used, basically, the same configuration oil pan and were 6 quarts capacity (with filter change). No other Chevrolet vehicle with big block used the same pan as Corvette.
