1971 Gauge Cluster Bezel - NCRS Discussion Boards
  • James C.
    • November 1, 2001
    • 137
    I know the cluster bezel has two attaching screws that require a fastener.What type of fastener is required. Mine are missing..Thanks!!
  • Warren F.
    • December 1, 1987
    • 1516
    Re: 1971 Gauge Cluster Bezel
    James,
    I'll take a stab at this. If I remember correctly, the two threaded nuts have the built in shoulder washer. If you are talking about the fasteners that thread onto the center instrument cluster studs that go thru the forward portion of the shifter console.
    • Jim T.
      • March 1, 1993
      • 5351
      Warren the two nuts do have an attached washer, the washers are the stared type. The size of socket to remove/install the nuts is 3/8. This is what came on my 70.
      • Warren F.
        • December 1, 1987
        • 1516
        Thanks Jim. I knew they were something out of the ordinary, it's been 17 years since I had one of my '70, '71 instrument clusters out and the center console removed.
        • James C.
          • November 1, 2001
          • 137
          Thanks! Jim
