Hi All,
My car has about 1100 miles on it since the frame off.
I have breakerless ignition, otherwise everything else is original on the car. Friday while driving the car it died out at around 35 mph as if the ignition was turned off. The car came back to life and I pulled off the road when safe. I turned the car off and inspected for loose wires...found nothing. The car would not start back. I thought perhaps the coil was hot or the breakerless ignition was malfunctioning. I let the car sit for 15 minutes and wiggled the battery switch some.. the car started back and ran fine. I do have a Chinese made battery cutoff switch on the battery and though that was causing a bad ground. Took that off ran the car with no problems. I thought maybe that was it. I put it back on the car just to retest this switch and sure enough the car cut out again, but with the car idling I turned the switch off and the car still ran fine. So now I dont think that this switch could be the problem. Am I right or wrong on about this? I feel like I have a bad ground or something similar.
What do you guys think?
