'68 wiper arm and door lock - NCRS Discussion Boards
  • Dave F.
    • December 1, 2003
    • 508
    Two questions:
    1. Are the '68 windshield wiper arms unique to that year, and if not, with what years might they be interchangable?
    2. Are the push-button door lock units side specific? The AIM does not call out LH or RH but some listings I have seen on eBay do make the dinstinction. It seemed to me the rod and clip attachment could be mounted on either side, but without having these I cannot tell for certain.
    Thanks in advance for any help on these two items.
    Dave
    • 43248
    Re: '68 wiper arm and door lock
    Originally posted by Dave Fleeman (41052)
    Two questions:
    Dave
    Dave-----
    The 1968 outside door lock and button assemblies WERE side-specific. The left side was GM #9716405 and the right side was GM #9716404.
    The 1968 Corvette wiper arm assemblies were unique to the 1968 Corvette and were not used on other year model Corvettes or any other GM car.
    • Harmon C.
      • August 31, 1994
      • 3228
      I have one wiper arm I think is a 68 and the only difference I see is their is no clip to attach a washer tube because 68's did not use the tube.
      Lyle
      • Dave F.
        • December 1, 2003
        • 508
        Lyle,
        By saying "difference", do you mean between '68 and other early C3's? And is the one you have up for adoption?
        • Dave F.
          • December 1, 2003
          • 508
          Dave-----
          Noted. Thanks much Joe.
          • Harmon C.
            • August 31, 1994
            • 3228
            Dave
            If we are lucky maybe someone will know if 68 wiper arms are the same as 69-73 without the tubes. Do they mount in the same place? Joe what do you think?
            Lyle
              • 43248
              Dave
              Lyle-----
              I'm not sure on this one. There may be some other subtle difference between the 1968 and 69-73. I believe they mount in the same location and the transmission assemblies are the same. However, with 68, it's hard to say, for sure, on anything.
              • Dave F.
                • December 1, 2003
                • 508
                Lyle-----
                According to my AIM, the wiper arms are LH and RH specific, and since I only have one with no part number that coincides with the AIM, I cannot tell which one I have. There does not appear to be any reproduction arm available for '68 so now I am wondering if later model arms would work (for service use only of course) since the transmission seems to be common.
