396 Transmission Linkage Throw - NCRS Discussion Boards
  • John O.
    • June 30, 2000
    • 88
    Does anyone know what standard production 65 396 Transmission Throws were....either long throw or short throw....what's correct for PV.
    Thank you!
    John
    Re: 396 Transmission Linkage Throw
    All 4-speed Corvettes left St. Louis with the shift linkage set in the standard long-throw configuration.
    • John O.
      • June 30, 2000
      • 88
      John,
      Once again, thank you for your expertise.....James West and myself are sitting here in the garage getting everything set for the body drop and we greatly appreciate it!
      -John
      • Wayne M.
        • March 1, 1980
        • 6414
        Re: 396 Transmission Linkage Throw (etc.)
        John --- also the steering was in the (standard effort and response) holes furthest from the spindle on the tie-rod ends, for non-power steering cars.
        And the clutch pedal-to-pushrod bracket was set to standard release/regular pedal travel (not the stiffer quick clutch holes). Am I right ?
        The latter clutch adjust is not mentioned, AFAIK, in the '65 TIM&JG.
        • Michael H.
          • January 29, 2008
          • 7477
          In addition to cars equipped with power steering, the tie rod location was in the forward/fast steering position for all 63 Z06 and, I believe 64 with the equivalent option package.
          Pretty sure 67 L88 was also in the forward holes. Dunno about 68-69 L88.
          • Dick W.
            • 10483
            '68-'69 in forward holes too Michael
            Dick Whittington
            • Michael H.
              • January 29, 2008
              • 7477
              Thanks Dick. I knew you'd know the correct answer. With my limited knowledge of C3, I wasn't sure. I still can't tell the difference between a 68 and 69 unless I look at the VIN tag.
              • Dick W.
                • 10483
                Door handles and backup lights Michael
                Dick Whittington
                • Michael H.
                  • January 29, 2008
                  • 7477
                  Oh. Yea, I knew that. Just forgot I guess. Which one has backup lights?
                  • Dick W.
                    • 10483
                    I don't know the answer to those hard questions
                    Dick Whittington
