Radiator Resto Advice - NCRS Discussion Boards
  • James S.
    • June 22, 2008
    • 226
    Hello,
    Is there a resto shop out there that know's how to restore an original 60 Vette radiator?
    Thanks in advance.
    Goatster
    • 43281
    Re: Radiator Resto Advice
    Originally posted by James Sanny (49162)
    Hello,
    Thanks in advance.
    Goatster
    Goatster------
    If you're talking about a 1960 ALUMINUM radiator, there's no way to restore them. The best bet there is a DeWitts reproduction. Not cheap, but the only way to go.
    If you're talking about a copper/brass radiator, you can obtain a core from DeWitts which is a correct reproduction of the original core in both configuration and function. Then, just about any competent radiator shop should be able to remove and install your upper and lower tanks on it.
    • James S.
      • June 22, 2008
      • 226
      Goatster------
      Thanks Joe! As usual, I recieve excellent advice from members.
      • James S.
        • June 22, 2008
        • 226
        Goatster------
        Joe, What a great web site Dewitt has.
