does The Factory Put Any Marking On Actuators From Factory ,saw A 71 With What Look Like Red Marks On Each Facing Front Of Car.
72 Headlight Actuator Markings
New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.Tags: None- Top
Re: 72 Headlight Actuator Markings
Red dots on the actuator by the vacuum fitting that faces the rear of the car because the vacuum hose with the red line hooks up to that fitting. It helped the line workers to correctly install the correct vacuum hoses. Usually not on 1972s, almost always on 1970 and it seems to be less frequent on 1971. Relax and enjoy your Corvette.Terry- Top
