My dash lights are dim but they are on I think . is this a switch problem-- a fuse problem or ?? any thoughts.
dim dash lights.-67 small block
Re: dim dash lights.-67 small block
Quickly run a jumper wire from the cluster to a good ground, and see if that helps. There is a spade connector ground at the top of the cluster that MUST be connected to provide ground for 2 gauges and cluster lighting.Last edited by Joe C.; September 18, 2008, 05:35 PM.- Top
