C2 shock washers--Joe L?
Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
Original member of the Kansas City Chapter, est'd 07/11/1982.
Member: 1965 and 1966 National Judging Teams
Judging Chairman--Kansas City Chapter.
Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
Tags: None- Top
Re: C2 shock washers--Joe L?
Tony -- I seem to remember when attending Vancouver B.C. (new chapter) judging school, that the '63-64 TIM&JG called for the smaller top washers for '64 (at least). Do you (or others) know if this is the case ?- Top
Definitely. These larger washers are 65-82 pieces. Also, originally used on some early Chevy II's.In Appreciation of John Hinckley- Top
Oh, by the way,
if you are looking to buy the upper shock washers, be sure to confirm that are not actually the upper "A" arm shaft end washers.
They appear to be the same, they are not! They vary in the concave depth.
HaND- Top
Curt-----
Attached is a photo of a GM #25628204. This piece is almost identical to the GM #43468 or GM #5544049 used for 1963 Corvettes and GM #5544049 used for 1964 Corvettes. As I recall, the originals are a tiny amount thicker and with a slightly different curvature to the raised portion. You would virtually need to have them side-by-side and using a magnifying glass to see the difference.In Appreciation of John Hinckley- Top
Anthony, See July14, 2006. Jim Lennartz for three nice pics of the shock washers. I didn't read all of the posts in detail but in scanning I missed seeing what month and year you Corvette is. Just guessing you probably need the shock washer that has the hex indentation. The center pic of Jim's three shots. The ebay ones are the oriental hat ones and aren't worth a crap for a 63-64. You actually need a bunch of the correct washers. Need the same washer for the sway bar rubbers. So therefore you need at least 6 of them. Originals are big bucks and hard to find. Email me if you need more info. Jorjorian had a nice pic of a bag of NOS ones but the photo is gone. Or if its there I cannot find it. John- Top
