65 SB Exhaust Manifold Spacers - NCRS Discussion Boards
  • Michael S.
    • June 7, 2007
    • 82
    The judging guide seems to indicate that spacers were used on all the exhaust manifold bolts. But I have been told that spacers were only used on the 4 end bolts with the French locks on each manifold and not on the 2 longer center bolts. Thanks for any clarification on this. Mike Sparr
  • Mike M.
    Director Region V
    • August 31, 1994
    • 1463
    Re: 65 SB Exhaust Manifold Spacers
    Hello Michael
    Search back through the earlier pages here on the TDB or through the archives.
    This topic was covered very specifically and in great datail just a few days ago.
    HaND
    • Joseph T.
      • March 1, 1986
      • 169
      Michael,
      There should be no washers located in the center position of the exhaust manifolds. Only location is under the french locks (4 spacers per side). I believe there was a mis-print in the Judging Guides.Good Luck.
      • Michael S.
        • June 7, 2007
        • 82
        Joe -
        Thanks for the response and clarification.
        I should have done a search on the archives first to see if this issue had already been responded to. There is often an abundance of good info already in the archives that a member can refer to.
        Mike
