55-57 Dist rotor - NCRS Discussion Boards
55-57 Dist rotor
  • Roy B.
    • February 1, 1975
    • 7044
    55-57 Dist rotor
    I posted some time back about the original Dist. Rotor for the 55 Corvette which was original equipment to reduce Radio static. Any one interested here they are , some Corvette dealers change Big $$$ but now and then you can find them cheap on e-bay , as you see they were used on other then Corvette.
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 55-57 Dist rotor
    Originally posted by Roy Braatz (182)
    ....0riginal Dist. Rotor for the 55 Corvette which was original equipment to reduce Radio static. Any one interested here they are , some Corvette dealers change Big $$$ but now and then you can find them cheap on e-bay , as you see they were used on other then Corvette.
    I dunno Roy; there's at least 3 NOS Delco units on eBay right now. Here's one; they vary from $7 to $15. These are in the orange/white pull-string boxes D-403 # 1917249. Don't know why such an ancient item should be still available, but no '55 Corvette NCRS owner has an excuse for not grabbing one now (rather than a Filko aftermarket). I've seen one in a modern box (red/white/blue) but seems not to have the resistor anti-static feature (although functionally equivalent to original).
    • Roy B.
      • February 1, 1975
      • 7044
      AS you see they were used in many different models and works ,some people may not think of buying one because it cant be seen or judged
