1960 Carb question - NCRS Discussion Boards
1960 Carb question
+ More Options
Posts
  • David D.
    • January 1, 2005
    • 416
    1960 Carb question
    Friend of mine has a numbers matching '60. His carb has been running lousy since starting after 5+ years.
    We are have a couple problems.
    1) The carb has no visible numbers anywhere, just Rochester 4 Jet, GM, RP. In looking at the JM and other guides we see that the car seems to have only come with Carter WCFB carbs. So, is the Rochester an after market GM replacement carb, or was it possible to have one come with a Rochester?
    2) Trying to find a possible re-build kit for the Rochester carb, how best to proceed without removing and/or disassembling. Any ideas how to date this Rochester Carb?
    Some Pics attached, more available if it will help identifying.
    Thanks in Advance,
    David
  • Jimmy G.
    • November 1, 1979
    • 978
    Re: 1960 Carb question
    David
    not sure what it is but it is not a Corvette carb. Buick, Caddie maybe
    • Mike E.
      • February 28, 1975
      • 5153
      The Rochester had the same size on the bottom, so it bolted onto a Corvette intake manifold, and was often used by people over the years as a replacement carb. It is NOT correct.
      • David D.
        • January 1, 2005
        • 416
        OK, thanks for the replies....
        Any good place to find a 'Correct' Carter WCFB ?
        What are things to look for when looking ? Any particular numbers?
        I believe it is a late '60.....
        Thanks again,
        David
