Tach test C2 - NCRS Discussion Boards
Tach test C2
  • Larry S.
    • September 19, 2007
    • 204
    Tach test C2
    I am not sure of how accurate the cable drve tach (original) is on my '66 BB.
    I tried to hook up an electronic tach test-meter, the usual way as you would on a points distributor, but, my car has the transistor ignition and it wont work. Has anyone ever found a way to connect an electronic tach to a TI setup?? I would also want to use the tach testmeter to map the distributor too. Thanks in advance for any ideas.
    Re: Tach test C2
    You might want to talk to Dave Fiedler (www.tispecialty.com) , the T.I. "guru"; he can probably help you. I recall a caution from GM in the Shop Manual that using the wrong type of test equipment can damage the T.I. amplifier.
    • Larry S.
      • 204
      Re: Tach test C2
      Okay Thanks John, I contact him.
      • Joe R.
        • March 1, 2002
        • 1356
        Re: Tach test C2
        Many of the newer timing lights have a tachometer mode, so you could avoid the TI problem that way.
        By the way, you are wise to test the accuracy of your tach. I recently tested mine and found it was reading about 15% low. Not a good thing if you like to periodically run your engine out to the indicated redline.
