I'm just re-wrapping harnesses getting ready to install the engine, and I have an wire that came off of the 12v (BATTERY) terminal of the solenoid that is not shown in the Hayes or Chilton diagrams that I have.
There was definitely a previous meltdown in the lower harness that was repaired (Bubba).
There is a Red #12 going to the fuse link wire to the battery terminal.
There is a smaller Red (purple?) wire that came from the start side of the solenoid.
There is a black ground wire that was attached to a bellhousing bolt.
The mystery wire is a Black
(could be blue) wire, about 14/16 ga, with a fuse link and large ring terminal in it. It definitely came off of the battery terminal, and appears to be in the original engine harness, and goes all the way back to the bulkhead connector.
Can anyone shed some light on this for me?
(could be blue) wire, about 14/16 ga, with a fuse link and large ring terminal in it. It definitely came off of the battery terminal, and appears to be in the original engine harness, and goes all the way back to the bulkhead connector.Can anyone shed some light on this for me?
