66 Power brake booster mounting - NCRS Discussion Boards
  • Peter J.
    • September 30, 1994
    • 586
    The judging guide states that the mounting plate is secured with two flat rivets but I have seen an original 67 with rounded head rivets and this 67 car is a known original. The mounting kit I have also has the same rounded head configuration. I was just curious what other 66 cars have on theirs. I have the correct mc and booster and want this to be as correct as possible.
    I am doing this swap because I will be driving this car a lot when it is back on the road and like the idea of a split braking system for safety reasons.
  • Jeffrey G.
    • June 30, 1986
    • 77
    Re: 66 Power brake booster mounting
    Peter,
    I'm considering adding power brakes to my 66' and I would like to do the install as factory as possible too. Where did you buy your mounting kit?
    I assuming the plate came with it. Do you have any other suggestions for performing this conversion?
    Thank you!
    • Peter J.
      • 586
      Jeff,
      I am getting ready to do my install and will let you know how it goes. It has been quite a while since I got the mounting kit (2 bolts, Plate with weld nuts and rivets), but I got it from Long Island. I will be going with flat rivets as the JG says. I had hoped somebody with a 66 would chime in with photos or a description of their rivets. I'm sure Paragon would have it too. Tough part was finding the master cylinder at a good price.
      • Jeffrey G.
        • June 30, 1986
        • 77
        Peter,
        Thanks for getting back to me. I'll look in the LI catalog for the mounting kit, did you buy the flat rivits from them too? I was suprised not to hear from any other 66 owers either. Please do keep me posted on your install, I'm a couple of months from begining. Thank you, Jeff jgoldacsind@yahoo.com
        • Mike M.
          Director Region V
          • August 31, 1994
          • 1463
          Caution: as there has not been any mention of the nut plate, the repops we have seen on the judging field have hex head weld nuts, originals were square.
          HaND
