C1 Mounting Wiper Transmission - NCRS Discussion Boards
  • Richard H.
    • March 1, 1985
    • 241
    Am I correct in assuming that a set screw/bolt is placed in the hole in the bracket mounting the wiper transmission so that the shaft will not slide down when depressed in the process of connecting the cables? If so, the size of such a screw/bolt? If I am not correct in my assumption, how does one prevent the shaft from sliding down as the bracket when attached is below the flat section of the shaft and offers it no support. Thanks. Richard
