Diverter Valve Numbers--which Car? - NCRS Discussion Boards
  • Paul C.
    • November 12, 2007
    • 511
    I have a diverter valve with the numbers #7034481 on the tube that connects to the check valves and the number under the valve (very hard to read) looks like 29296. Anyone have any idea wht vehicle this is from? I was using it on a 1971 LT-1 but got another one (#29199) which is correct. The pump is was attached to has no date but says 1973 inside and has the numbers 7801149. Thanks Paul
    • 43277
    Re: Diverter Valve Numbers--which Car?
    Paul----
    GM #7034881 is the casting number for a component of the diverter valves; it is seen on several different valve part numbers. Diverter valve GM #7029296 was used for 1969 series 10-30 light trucks with 350 cid medium duty engines.
    7801149 is a casting number used for a backing plate for AIR pumps from 1968 through 1975.
