CI 283 timeing question - NCRS Discussion Boards
+ More Options
Posts
  • Jerry J.
    • November 1, 2000
    • 54
    If my rotor is pointing at #1 wire and the damper is at TDC
    is the # 1 piston at TDC ?
    Thanks, in advance....
    Re: CI 283 timeing question
    You have to know the specific position of the valves (intake vs. exhaust cycle) to guarantee that! You can be 180 degrees off with only the information you supplied...
    • Jerry J.
      • November 1, 2000
      • 54
      Thanks Jack...
      That was the reason for my question, being 180* off.
      Am pulling valve cover again. It's a Fuelie and it ain't no fun....
      • Bill W.
        • November 1, 1977
        • 402
        Jerry, Pull the right cover instead. If both intake & exhaust on cyl #6 are loose you are at TDC on #6. Bill
        • Bob B.
          • March 1, 2003
          • 831
          • Jerry J.
            • November 1, 2000
            • 54
            Re: CI 283 timing question
            Thanks Bill That was much easier. Took all of maybe 20 seconds..
            Nice tip I won't forget....
