A/C condenser - NCRS Discussion Boards
A/C condenser
  • Dale S.
    • November 12, 2007
    • 1224
    A/C condenser
    Does anyone have the measurements of the 67 A/C condenser vs. a 1968 A/C condenser? Also any date codes, markings, part numbers, etc. to identify a 1967 from a 1968 condenser? On page G305 of my 1967 AIM, C-60, B-1, shows a part number of 3891735 for the 1967 condenser. Any help would be appreciated. Thank you Dale
  • Peter L.
    • May 31, 1983
    • 1930
    Re: A/C condenser
    Dale - Here you go on the 67 A/C condenser dimensions -
    Condenser Assembly w/ Mount Brackets - 30-1/2" wide
    Mounding Brackets - 9" high
    Condenser Coils - 25" wide x 14" high x 2" thick
    I could find no identifying marks.
    Hope this helps, Pete
    • Dale S.
      • November 12, 2007
      • 1224
      Re: A/C condenser
      Thank you Peter, I hope to see you at the meeting. Does anyone have measurements for a 1968 Condenser? Thanks dale
        • 43271
        Re: A/C condenser
        Dale-----
        I don't have dimensions. However, the 1968 condenser was a one-year-only piece. It was GM #3906084. It was discontinued without supercession more than 25 years ago.
        • Bryan M.
          • April 1, 1999
          • 386
          Re: A/C condenser
          The measurements of my 1968 repo condenser core is 24"w and 16"h. The tubes on each end stick out about 3/4".
          • Dale S.
            • November 12, 2007
            • 1224
            Re: A/C condenser
            Thank you gentlmen, can anyone give me measurments on an original 1968 condenser. Thank you to all on the thread. Dale
            • Dale S.
              • November 12, 2007
              • 1224
              Re: A/C condenser
              I guess no 1968 A/C car has an original condenser. Dale
              • Jimmy B.
                • July 31, 1980
                • 584
                Re: A/C condenser
                Dale,
                Don't know if I can help but I have the condensor out of my 69 350/350 and I could measure, photo, whatever if you would like tme to.
                Jim Blakely
                  • 43271
                  Re: A/C condenser
                  Originally posted by Jimmy Blakely (3742)
                  Dale,
                  Jim Blakely
                  Jim----
                  1969 used a different condenser. I don't know if it was the dimensionally the same as 1968, or not.
                  • Bryan M.
                    • April 1, 1999
                    • 386
                    Re: A/C condenser
                    I've only seen one NOS 68 condenser listed on ebay over the last 10 years. I could kick myself for not buying it.
                    • Dale S.
                      • November 12, 2007
                      • 1224
                      Re: A/C condenser
                      Thank you to all, I think we have found that the condenser on my 67 is correct. Dale
