Bolt Refreshing Cosmetics - NCRS Discussion Boards
  • Jack C.
    • September 30, 1992
    • 1090
    What oil/penetrant is recommended to freshen up some minor surface rusted bolts and give them a better look without using a wire brush.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
  • Chuck G.
    • May 31, 1982
    • 2036
    Re: Bolt Refreshing Cosmetics
    I use a soft brass wire brush, and then use some "gun blue" on them, IF you're looking for a dark finish.
    Chuck
      • 3416
      Hi Jack,
      I've used a soft brass brush as Chuck noted and then sprayed them with Pre-Lube 7, which seems to really put off the return of rust if the car lives a fairly easy life.
      • Steven B.
        • June 30, 1982
        • 3997
        I have used both the brass brush and 0000 steel wool if the rust is not bad and I do not "polish", just clean with the wool. I have used a number of penetrants and just made sure I wiped most of it off. I will try the gun blueing.
        • Jack C.
          • 1090
          Thanks for the tips.
          Jack Corso
          • Alan D.
            • January 1, 2005
            • 2046
            I used RidRust for these small parts. If you brush off with brass brush however sometimes a gold tint can be seen.
            • Gary S.
              • July 31, 1992
              • 1633
              Can't remember who on this board, but someone suggested putting bolts in a rock tumbler and using walnut shells to freshen them up. Easy to do since all you do is put them in the tumbler, turn it on and walk away.
              Gary
              • Jack C.
                • 1090
                The bolt refreshing I mentioned was for the bolts to remain on the car.
                Thank for the ideas.
                Jack Corso
                  • 11659
                  Gary
                  Yes, if you have most of the original black finish on the bolt, this process works very well.
                  Patrick
