71 Bb Fuel Lines - NCRS Discussion Boards
71 Bb Fuel Lines
  • Jeff M.
    • February 1, 1999
    • 127
    71 Bb Fuel Lines
    What is the purpose of the small secondary fuel line that goes into the bottom of the pump?? Can i block it off when using an after market high capacity pump? Should i plug it off leave it open? I rhought it is part of an emissions piece
    Re: 71 Bb Fuel Lines
    By '71, tanks used SEALED gas caps. The secondary line from the pump back to the tank is there for pressure relief...
      • 43247
      Jeff-----
      It's a fuel return line. Among other things, it helps prevent vapor lock. You can eliminate it if you use a fuel pump that has no provisions for it. You should cap off the line if you use a pump without the feature.
      Actually, though, my recommendation would be to use a stock type fuel pump and leave the fuel return line connected. For a STREET application, I wouldn't try to re-engineer the fuel system.
