C1 Part Paint/Finish question (1957) - NCRS Discussion Boards
  • Ashley S.
    • November 1, 2005
    • 146
    What should the finish be on the following parts?:
    1) The clutch pedal bumper bracket.
    2) Brake Light switch bracket.
    3) Brake Light switch housing itself.
    4) Brake pedal pull back bracket
    5) The (approx 1/2") pin that goes through the brake pedal pull back bracket.
    6) Brake pedal return spring.
    Ashley
  • Gary C.
    Administrator
    • October 1, 1982
    • 17881
    Re: C1 Part Paint/Finish question (1957)
    Ashley, easiest way to describe it is that everything from the clutch rod downward is painted. Everything above the clutch arm is bare on the pedal arms. The brake like switch mount bracket and clutch stop bracket are painted along with the main pedal mounting assembly. This's just come to be realized in the last two years from the Bowtie original '56 & '57's we've seen. Before this the thoughts were everything was painted. Gary....
    p.s. send me an e-mail gchesnut@charter.net and will send you a photo as I'm max'd out on my photo attachment space
    NCRS Texas Chapter
    https://www.ncrstexas.org/
