78 pace car transmission - NCRS Discussion Boards
  • Hugh A.
    • June 2, 2008
    • 31
    The various documentation with my 78 pace car alternate between references to M38 automatic transmission and references to MX1 automatic transmission. Any easy way to determine conclusively which is installed?
    • 43281
    Re: 78 pace car transmission
    Hugh-----
    They are, essentially, the same thing. M38 indicates a THM-350 transmission. MX1 is a "merchandising option" for a 3 speed automatic transmsission (in this case, a THM-350).
    • Gary B.
      • September 30, 1987
      • 305
      Does your Vette still have the option sticker still on it?
      • Tom R.
        • June 30, 1993
        • 4103
        Hugh, an article has submitted to the Restorer that is scheduled for publication I believe in the Winter Edition re 78 transmission and it touches on this topic.
        Essentially, GM tagged a number of RPOs codes (regular production option) as merchandising options. It gave zone/factory the option to change the parts out for installation but permited dealers to order the option. MX1 (M38) is the merchandising option for automatic transmissions while MM4 was used for M20 applications.
        What this means is that if you matched up a window sticker with same VIN and its build sheet mate...you'll see two different RPOs printed out. MERCHANDISING OPTIONS will always show up on production documents (retail documents) while build RPOs will always show up on build sheets...and these will reconcile with the AIM for that particular model year. MX1 is not a part number...it's an ordering number while the M38 is the actual part number.
        I believe in 76 or 77, the M38 was introduced for the lower powered L48 engine while the heavy duty M40 was continued to be used for L82 application...essentially the was a GM cost savings measure. In the case of four-speeds a dealer would order an MM4 but the factory would install a Muncie cast iron 4-speed when L48 was called out while L82 applications got the Borg Warner all-aluminum M20 4-speed.
        A study of build sheets confirms what's described above for both MX1s and MM4s and is documented in the article on 1978 four-speeds.
        Hope this helps
        Tom Russo
        78 SA NCRS 5 Star Bowtie
        78 Pace Car L82 M21
        00 MY/TR/Conv
        • Hugh A.
          • June 2, 2008
          • 31
          Hi Gary, no I don't have the option sticker.
          • Hugh A.
            • June 2, 2008
            • 31
            Hugh-----
            Joe, thank you.
            • Hugh A.
              • June 2, 2008
              • 31
              Tom, thank you for the info - I look forward to reading the article.
              • Roy B.
                • February 1, 1975
                • 7044
                I think the MX1 was a 350 trans ordered ( heavy duty )when ordering the trailer package that I did which my 78 had MANY changes to the Corvette , Radiator ., shocks,Alternator,battery,sway bars,trans and so on.
                • Hugh A.
                  • June 2, 2008
                  • 31
                  Roy, thank you.
                  • Tom R.
                    • June 30, 1993
                    • 4103
                    Roy...same tranny was used for either application...M38. Read above note re the MX1=MERCHANDISING OPTION.
                    Tom Russo
                    78 Pace Car L82 M21
                    00 MY/TR/Conv
                    • Roy B.
                      • February 1, 1975
                      • 7044
                      I dont know anything about the MX1 that's why I said (I think it may be)
