870 Block Identification - New Member Needs Help - NCRS Discussion Boards
  • Peter C.
    • August 26, 2008
    • 8
    Dear NCRS members:
    My name is Peter Cook and I am a new NCRS member. I have been reading your technical discussions for the past few weeks and I have been impressed by the vast pool of knowledge and how helpful everyone is. I hope that you can all help me with proper identification of this 870 block.
    My vette is a 1964 roadster (VIN 40867 S107393 and "D18" assembly date) which I purchased two years ago without the original motor in it but with a block, crank, pistons, rods and heads which were purportedly the original block and heads for the motor. The block and heads were severely rusted from being left out in the elements for many years.
    A month or so ago I finally got around to trying to disassemble the engine but it was so rusted up I needed to bring the block to a machine shop for disassembly. During my attempted disassembly of the block, pistons and rods I noticed that the following: i.) all of the main, cam and rod bearings were brand new; ii.) the distrbutor was no longer attached to the engine but the distributor shaft was still there with its gear enmeshed with the camshaft; and iii.) there were no numbers or letters on the engine stamping pad. I discussed these facts with the machine shop and they seemed to believe that the block had been rebuilt many years ago (including the block being decked) and the distributor gear failed at initial start-up or shortly thereafter causing the engine to be shelved.
    Before sinking anymore money into this block I want to identify this block so that I can be sure of what I am dealing with. The block markings and information are as follows:
    1.) Engine block no. 3782870;
    2.) Foundry date on rear lip of block is "K28";
    3.) No engine pad stamps (apparently block was previously decked);
    4.) Ten dot forging clock above block no.;
    5.) Tell-tale Saginaw/Flint plug above timing chain area;
    6.) The numeral "3" next to the letters "GM" directly below the casting number; and
    7.) The machine shop has confirmed that this is a small journal block.
    Questions that I trying to get answered include the following:
    a.) Why does this block with a K28 casting date , apparently November 28, 1963, have no year included in the casting date?
    b.) According to my calendar November 28, 1963 was the fourth Thursday in November (viz., Thanksgiving day), was the Saginaw foundry really working on Thanksgiving day back in 1963?
    c.) Does the "3" next to the letters "GM" indicate that the block was cast in 1963?
    d.) Why does this block have a 10 dot clock on it if forged in 1963 (other threads indicate that this was feature did not appear uintil some time in 1964)?
    I look forward to your responses.
    Best regards,
    Peter Cook
    Direct view of pics from photobucket
    http://i436.photobucket.com/albums/qq87/xcookpac/09062008_870_1.jpg
    http://i436.photobucket.com/albums/qq87/xcookpac/09062008_870_2.jpg
    http://i436.photobucket.com/albums/qq87/xcookpac/09062008_870_3.jpg
  • Chuck G.
    • May 31, 1982
    • 2039
    Re: 870 Block Identification - New Member Needs Help
    Looks like K 2 3 to me. Often hard to tell 3's from 8's in small castings.
    The casting clock shown began in 64 model year usage as I recall.
    Chuck
    • Chuck G.
      • May 31, 1982
      • 2039
      Here's the pic direct.
        I agree - K 2 3 (November 2, 1963), not K 2 8.
        • Steven B.
          • June 30, 1982
          • 4020
          Isn't there a method, using heat I believe, to bring numbers traces out from a pad that has been decked?
          • Boyan B.
            • August 31, 1999
            • 189
            Peter, can you post a photo of the engine pad? Sometimes, even when decked, you can see the original numbers still on the pad. You will loose minimum 38 points due to the broach marks, but in my opinion, if it's your original engine, I would do everything to keep it and live with it being decked.
            Its better than a "restoration" or "restamp" which is always suspect.
            Boyan 818 517-5016
            • Philip C.
              • December 1, 1984
              • 1117
              Originally posted by Peter Cook (49371)
              Dear NCRS members:
              Best regards,
              Peter Cook
              Hi Pete
              1) 3782870 blocks were used in corvette from 62 model year to 65 model year.
              2) casting date K23=Nov. 2nd 1963, for use 64 model year.
              3) You dont show a photo of the pad.
              4) Casting clocks started the experts say June 63 for Saginaw earlier for Tonawanda. I say earlier for Saginsaw/ Flint but that my two cents.
              5) Front plug OK all Saginaw/ Flint had'em
              6) #3 casting on block. They had more than one casting mold, so they numbered them.
              7) Should have small journal.
              A) See #2 above
              B) See #2 above
              C) NO see #6 above
              D) See #4 above
              Phil 8063
              em
              • Peter C.
                • August 26, 2008
                • 8
                Thank you for all your help.
                I now feel much more confident about my 870 block and really learned something about the difficulty of identifying a casting code "3" versus an "8". It feels great to be a member of such a great organization where members come to the mutual aid of other members.
                Best regards,
                Peter Cook (49371)
                New NCRS Member
                PS I ran out of batteries while I was at the machine shop so I was not able to take a picture of the block stamp pad but it appeared completely blank (so I figured what is the point of going to get batteries in order to take a picture).
