Zr-1 - NCRS Discussion Boards
Zr-1
  • Bill M.
    • 1328
    Zr-1
    Does anyone know where i can get a clutch slave cylinder and oil cooler hose assembly for a 1990 ZR-1
    • 43255
    Re: Zr-1
    Bill----
    The slave cylinder is easy. The GM part number was 10147948. It's discontinued, and I can't find any new number for it, although there may be one. In any event, you can obtain this cylinder under NAPA #UC 37838 or Raybestos #SC 37838. The same cylinder is likely available under other brands, too. I think you will find that any of these are identical or virtually identical to the original. GM never manufactured these. I believe the current aftermarket manufacturing source is the same as GM's.
    The oil cooler hose is another matter entirely. It was GM #12472184 and it's discontinued. It was a ZR-1 only item and applicable only to 1990-93 year models. I don't know of any source for it, but you might try a C4 parts source like Corvette Central, Ecklers, or Mid America.
    • Bill M.
      • 1328
      Re: Zr-1
      Joe
      Thanks i was asking these questions for a friend of mine and i assumed that he went through all of the avenues of parts suppliers. When i questioned him he told me that he was only going through the chevy dealer. when i get home i will look through my vendor books.
      Bill
      • Paul H.
        • September 30, 2000
        • 688
        Re: Zr-1
        Joe
        Bill
        Bill try the guys over on the Corvette Forum under the C4 ZR1 section. They are a helpful group. Also, the ZR1 Registry is good with parts resources. Good luck.
