Towing a 1962 - NCRS Discussion Boards
Towing a 1962
  • Jeff C.
    • September 30, 1997
    • 233
    Towing a 1962
    Does any one have any experince towing a 62 with a tow bar.
    If so how did you attach the tow bar to the vett frame?
    Jeff
  • John F.
    • March 23, 2008
    • 2419
    Re: Towing a 1962
    See my "62 for tie-down" thread. I just towed mine on an open trailer about 1300-1400 miles each way with no problems. I would never use a tow bar and would prefer an enclosed trailer, but couldn't find one to borrow.
    • Mike E.
      • February 28, 1975
      • 5141
      Re: Towing a 1962
      To answer your question, rather than to tell you what you shouldn't do---when you take the front bumperettes off, there are 4 holes in the crossmember at that point. I have several friends who in the old days flat towed their cars many hundreds of miles with the tow bar bolted through the crossmember at those four points.
      If you are going to flat tow more than a few miles, you want to take the driveshaft out for the same of your transmission.
      • Richard T.
        • February 1, 1979
        • 858
        Re: Towing a 1962
        Flat towing these cars is pretty risky at best. If you must do it go to your local U Haul dealer and rent a 2 wheel dolley. This way you can get the front wheels in the air a little and use a decent bumper hitch assembly on your tow vehicle. Good luck. Rich
        • Bill M.
          • April 1, 1977
          • 1386
          Re: Towing a 1962
          Here's how they did it in the early 60s.
          • Roy B.
            • February 1, 1975
            • 7044
            Re: Towing a 1962
            If it's a PG trans you have to remove the drive shaft or you will burn up the PG because the rear pump will burn the PG
