Correct engine casting - NCRS Discussion Boards
  • Luis R.
    • August 31, 2002
    • 43
    I have a Corvette 1967 427 serial is 122268 and the body build date is K-21. I have two question, What date was the car final assamble? The engine casting number is 3916321 is that correct?
    Re: Correct engine casting
    To get to the car's final assy date, you 'interpolate' using its VIN against published Chevrolet end of month production figures. There are several 'birthday' calculators out there + a birthday book to reference.
    Bottom line, the interpolation process is 'approximate' but it's typically accurate within a few days of actual...
    The '321 engine block cast number IS considered correct for 'late' 1967 BB cars and it's discussed in the NCRS Judging Guide...
    • Rick S.
      • January 1, 2003
      • 1203
      Lius,
      Just for comparison, I have VIN 21135 which indicates either June 17th or June 19th (Sat or Monday) build date. The trim tag has a build date of K16 which is June 16th for the body build date. I would suggest you explore: www.c2registry.org and register your car.
      Rick
      • Mike M.
        Director Region V
        • August 31, 1994
        • 1463
        Luis,
        Link to the Wisconsin Chapter Website through this site, they have the Birthday data.
        HaND
        • Jason A.
          • June 30, 1998
          • 31
          Here is the link to the WI NCRS Chapter site.
          • David D.
            • December 1, 1977
            • 231
            Lius -
            I saw your post for info on 22268 and thought that number sounded familiar. I ran out to the garage and read 22273 from an old block that I have had for 20 plus years. This block is a 300 HP A/C car. It is fun to capture numbers. Good Luck and have fun.
            David Dawdy
