Kelsey 5 1/2 inch rims - NCRS Discussion Boards
  • John N.
    • September 30, 1998
    • 13
    I'm back up in Ct and was out in the shed and found 2 5 1/2 K rims. The date looks like 6/63. These are welded and were on the rear of my 62 when I bought it 20 years ago. It cost me a hubcap to find out it needed nubs to keep the hubcap on. They have the Kelsey-Hayes stamp. What are these for?
    John
  • William C.
    • May 31, 1975
    • 6037
    Re: Kelsey 5 1/2 inch rims
    A picture of the front of the rim might help. There were many 5 1/2 inch rims, 65-66 Corvette being one variant, and others in service. A search of the archives will bring up a fairly involved discussion on the '65-66 rims from a few weeks back.
    Bill Clupper #618
    • John N.
      • 13
      I tried to attach a couple of photos.
      John
      • Mike E.
        • February 28, 1975
        • 5138
        Is the valve stem hole a reasonably small hole (as opposed to your 62 which should have a larger valve stem hole)? Does it have two small raised bumps next to the valve stem hole? If yes to both question, and if the stamping says 15x5 1/2 JK (as I recall--I'm working from memory here at work) it would likely be a pair of 63 Corvette whels.
        • Tracy C.
          • July 31, 2003
          • 2739
          John
          Pics didn't upload to your post. I sent you an email, if you send me the pics, I can help you post them here.
          tc
          • John N.
            • 13
            I looked at the rims again. The valve stem hole is 1/2 inch and there are two dimples. It is a 5 1/2 K that is welded with no dog bones. There is a 63 and a 6 by the 5 1/2 k. Ican get you a picture if tou e-mail me at jlnomeyko@aol.com.
            John
            • William C.
              • May 31, 1975
              • 6037
              OK, given any luck pictures are attached. All I can add is they are not 65-66 wheels due to the dog dish hubcap features. Time for others to chime in!
              Bill Clupper #618
              • Mike E.
                • February 28, 1975
                • 5138
                Almost sure they are 63-64 wheels. They have all the elements:
                welded
                1) small valve stem hole
                2) correct date
                3) double nubs next to valve stem hole
                4) taper on the back side for pre-disc brake cars (don't have to clear the rotor)
                5) post-62 circumferential recess for seating the tire bead
                As Bill said, they are not 65-66 because of the presence of the protrusions around the center for mounting disc brakes, plus 2 and 4 above
                • Tracy C.
                  • July 31, 2003
                  • 2739
                  welded
                  2) correct date
                  Agree........
                  • John N.
                    • 13
                    Thanks for the help. Now what do I do with them? Anyone want to trade for a rim for my March 62 car? I'm sure they would look a lot better on a car than in my shed.
                    John
                    • Tracy C.
                      • July 31, 2003
                      • 2739
                      John
                      email sent.....
