67 trim tag conflict - NCRS Discussion Boards
  • Dereck S.
    • July 30, 2008
    • 244
    Recently had an opportunity to purchase a second owner 67 427 roadster that required complete restoration. The trim tag appeared to be original to the car. The car was an early VIN 13XX built in sepember of 66. The trim tag indicated the style to be 66 467 instead of 67 467. Is it possible that on early build 67 cars that the factory could have incorrectly stamped the trim tag?
  • William L.
    • December 1, 1988
    • 944
    Re: 67 trim tag conflict
    Dereck; Many years ago, Joe Trybulec and I interviewed the plant worker that ran the machine that typed the trim tags and if only 1/2 of his stories were true , it was very possible.
    Bill
    Bill Lacy
    1998 Indy Pacecar
    • Philip C.
      • December 1, 1984
      • 1117
      Hi Dereck no conflict at all, if its a real tag, YOU cant get a repo tag by the tag judges, My 64 coupe has its orig trim tag, but its stamped as a conv. Phil 8063
      • David B.
        • April 1, 1988
        • 42
        Dereck - I have seen at least three examples of early '67 cars with "66" listed next to Style. All were St. Louis cars, and all three tags appeared to be the real deal. Here's one from '67 serial no. 018X. I'd say chances are real good your tag is original.
        • Dereck S.
          • July 30, 2008
          • 244
          David,
          Thank you so much for the example of the trim tag you sent with the style listed as "66". My car is B21 and is a St. Louis car. I feel much better now that I likely do not have a counterfeit tag. I have and image of my tag I wanted to send you but have not been able to figure out how to add attachments yet. I'm a new NCRS member.
          thanks,
          Dereck
          • Rick S.
            • January 1, 2003
            • 1203
            Derek,
            I have a typo trim tag which has an incorrect color code, off by one digit. It indicates a Yellow car but the car has been Goodwood Green since rolling off the line. I researched and found the original owner who told me and provided documentation (letter & photos) that he bought the car off the dealer lot as Goodwood green. I also have the build sheet and POP which indicates that the car was green. I also consulted with Al Grenning and he feels that the trim tag is a typo and has used it as an example in his seminars. So, don't get too nervous with your trim tag typo as it was not uncommon back then.
            Rick
            • Rick S.
              • January 1, 2003
              • 1203
              Bill
              Bill,
              I wrote an article for the Michigan NCRS "Vette Signal" on my quest to clarify the typo trim tag for an incorrect color code. It would be interesting that you and Joe write an article about your interview with the St.Louis worker and share his experiences. I am sure many members would love to hear the stories. Plus, it would help many new judges understand that mistakes were made in the production of early Corvettes.
              Rick
              • William L.
                • December 1, 1988
                • 944
                Rick: We'll give it some thought.
                Bill Lacy
                1998 Indy Pacecar
                • Dereck S.
                  • July 30, 2008
                  • 244
                  Thanks to all who haved help put my mind at ease regarding the 67 trim tag typos. Attached is an image of my tag. It is identical to the one example David provided.
                  Dereck
                  • Rick S.
                    • January 1, 2003
                    • 1203
                    Derek,
                    You might try a new photo with less flash kick back but I see the error.
                    Rick
                    • Dick W.
                      • 10483
                      Old indian trick that I learned from John Hinckley, put a piece of tissue paper over the flash, it will reduce the glare!
                      Dick Whittington
                      • Rick S.
                        • January 1, 2003
                        • 1203
                        New, NOS or used tissue paper?
