Motor Mount Ground Strap - NCRS Discussion Boards
  • John O.
    • June 30, 2000
    • 88
    Myself and James West are restoring a 65 396 and have run into a delimma. In AIM/JG both indicate that the ground strap is to be on the right side motor mount. On this car, the frame has NO indication of it being on the right side...no thread marks in frame hole. However, the hole in the frame on the LEFT (driver) side clearly has threads in it. Should we change the position? Any advice would be greatly appreciated here.
    Thank you,
    John
  • Michael H.
    • January 29, 2008
    • 7477
    Re: Motor Mount Ground Strap
    Thank you,
    John
    Ground straps are seen on either side of unrestored cars. Some cars have ground straps on both sides.
    I would reinstall the strap on the side that you removed it from.
    • John O.
      • June 30, 2000
      • 88
      Mike,
      Thank you for your advice. I'll go ahead and reinstall on the drivers side.
      John
      • Donald S.
        • January 23, 2008
        • 183
        hi john the ground strap was and is on the left side of my 396 car ..Don..
        • Wayne M.
          • March 1, 1980
          • 6414
          Originally posted by Donald Smith (48429)
          .... the ground strap was and is on the left side of my 396 car ..Don..
          Don, others --- strap on pass. side of my extremely late L78. Don't think there's any hole(s) on driver side frame support for the motor mount.
          • Rick S.
            • January 1, 2003
            • 1203
            Just to make a notation, on my late 67 frame, which is a small block(L79), both sides are threaded for a ground strap.
            Rick
            • Tom D.
              • September 30, 1981
              • 2132
              1966 Corvette number 2999 (October, 1965 build) had a ground strap on left front motor mount. There is a hole on the right side also, but no bolt or strap. I have not seen a frame with only one hole for motor mount ground straps.
              https://MichiganNCRS.org
              Michigan Chapter
              Tom Dingman
              • Michael H.
                • January 29, 2008
                • 7477
                Tom,
                I agree. I think both left and right side ground strap holes were already drilled when the frames arrived at the St Louis assy plant. The holes were not threaded though.
                When ground straps were used/installed, a self threading screw was used.
                There's a great picture floating around of a new 66 chassis on the St Louis assy line as the engine is being dropped into the chassis. There is definitely a ground strap attached to the motor mount bolt of the left/drivers side mount.
                I have that picture but it's too large to post here. I can shrink it down and crop to show just the area of the mount and strap if necessary.
                • Alan D.
                  • January 1, 2005
                  • 2038
                  Tom, I'll confirm what Michael said - both drilled but only one has threads. My Mar64 has strap on passengers (rt) side only. Note I've owned pre-NCRS and its only been maintained not a frame off restoration.
                  • Tony S.
                    NCRS Vice President, Director Region VII & 10
                    • April 30, 1981
                    • 987
                    John. My July 29th 396 car had the ground strap on the passenger side.
                    You face the dilemna every diligent restorer faces: should I restore my car the way it was manufactured or by the "standard" called for in a judging guide? For what it's worth, I'd say that you should just be true to your car. If that's how your car was built, then your car is trying to tell you something. Both you and James have made an honest effort to faithfully restore your car. I think "restore" means restore it to how it was born. If experience in this hobby has taught me anything, it's that there were alot of variations in the build process.
                    I'm sure you two will make the right decision for your car.
                    Good luck. I'm anxious to see your car again.
                    Tony
                    Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
                    Original member of the Kansas City Chapter, est'd 07/11/1982.
                    Member: 1965 and 1966 National Judging Teams
                    Judging Chairman--Kansas City Chapter.
                    Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
                      Both engine mount brackets on the frame had a pre-pierced hole in the forward wall; my '67 small-block had the ground strap on the passenger side, and the hole in the driver's side bracket had no threads in it, so it never had a ground strap screw on that side. Photo below shows the '66 L-79 at engine drop on the Chassis Line Michael was referring to, with the ground strap on the driver's side.
                      • Tom D.
                        • 2132
                        Thanks guys. Here's a photo of the unthreaded hole, right (passenger) side of a '67, number 11532.
                        Michigan Chapter
                        Tom Dingman
                        • Ray K.
                          • July 31, 1985
                          • 369
                          June 1st production L78 / 396 has the ground strap on the left ( drivers ) side.
                          Ray
