Cooling System Question - NCRS Discussion Boards
  • Jack C.
    • September 30, 1992
    • 1090
    If the radiator cap (no expansion tank) is not up to par, say a cracked pressure ring. What would be the symptoms if any?
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    Re: Cooling System Question
    Jack -
    A poor pressure seal would allow the coolant to boil at a lower temperature; you might note "puking" through the overflow hose during hot-soak after shutdown where you had none previously.
    • Jack C.
      • 1090
      Thanks John.
      Jack Corso
