1965 Rear Power Vent - NCRS Discussion Boards
  • Jimmy G.
    • November 1, 1979
    • 977
    OK I need some help. I need to reinstall my rear blower moter assembly but I am having a b***h of a time. Does the motor / fan go in first, the plastic tunnel, or do I have to put it in as an assembly with the band holding them together. What a job!!!
  • William H.
    • March 1, 1999
    • 249
    Re: 1965 Rear Power Vent
    Hello Jimmy,
    I just put mine back together after replaceing the rear wireing harness.
    Put the tube in first ( with the coupling pushed ofer the end), and angle it toward you at the back then put the fan in, ( thats the hard part have to spin it around some) Then with the junction of the fan and the tube angled towards you mate them together at the same time you push the whole thing away from you. then slide the coupling from the tube over the joint.
    Hope this helps,
    Bill
