Wiring Harness - NCRS Discussion Boards
Wiring Harness
  • Dave G.
    • February 21, 2007
    • 14
    Wiring Harness
    I am looking for a wiring harness for my 64 roadster, something that is an OEM type replacement that has all the appropriate connectors.
    I also plan on sending the gauge cluster out for restoration at the same time.
    Any advise on who and what to use would be appreciated.
    If you have any installation tips I would like to hear them.
    Thanks for your help
  • Jeffrey S.
    • April 1, 2004
    • 133
    Re: Wiring Harness
    Electriclimited (spelling probably wrong) makes them. Look on the internet you should come up with their web site. hope this helps Jeff
    • Guest
      Re: Wiring Harness
      Lectric Limited - http://www.lectriclimited.com/contact_us.htm
      all their contact info, etc. there
      for cluster restoration - Rick's Restoration in Maryland - have contact info at home and will post
      • Alan D.
        • January 1, 2005
        • 2053
        Re: Wiring Harness
        Dave if you desire cables "that has all the appropriate connectors" then save all yours. It's simple to replace the repro's with your old correct ones. A few of the connectors are not the same and a judge will pick those out.
        Also inspect the wire color closely since some are a little off.
        So save the old stuff!
        • Stephen L.
          • May 31, 1984
          • 3162
          Re: Wiring Harness
          Dave, before you purchase a new under dash harness, inspect your old one. It may just need a good cleaning and retape. Underhood harnesses are a different story as they experience the elements more.
          For some self satisfaction, disassemble your cluster and do the cleaning and simple painting yourself. Send your individual instruments out if you don't feel comfortable doing them. This is the fun of working on your own stuff....!
            Re: Wiring Harness
            M&H harnesses are also excellent, and are the only ones that come with the correct metal bulb sockets.
            www.wiringharness.com
