C2 windage tray? - NCRS Discussion Boards
C2 windage tray?
  • Brian K.
    • May 31, 2004
    • 358
    C2 windage tray?
    Question, did any of the 63 thru 67 327's with the standard non SHP oil pan also use a windage tray suspended from the main bearing caps? If so which ones and any part numbers for the trays. Thanks Sincerely Brian
    • 43281
    Re: C2 windage tray?
    Brian------
    NONE. For 63-67 small blocks, only those SHP equipped with the "6 quart" oil pan used an external baffle (windage tray).
    • Stuart F.
      • August 31, 1996
      • 4676
      OK Joe, have it your way - 6 quarts it is in your State. What is that in liters?
      Stu Fox
