Re: 67 Carpet Cut Outs for Seats
PT,
My new front set came in a box labelled ACC even though I ordered the set from Corvette America. Was surprised that the dimmer switch grommet was not included.
Pain in the neck to position the dimmer switch grommet, since the carpets I took off had it slightly off position. Finally triangulated the position, from the left screw hole of the pedal pad and got it right after an on and off 3 times.
So if your dimmer switch grommet, is in good shape you can reuse it. I had the time to get a new one once I realized the omission.
Good Luck with yours, email me if you want a better copy of that diagram.
PT,
