Rear Yoke Clearance - NCRS Discussion Boards
Rear Yoke Clearance
  • Bob U.
    • April 30, 2001
    • 21
    Rear Yoke Clearance
    What is the clearance tolerance between the end of the Yoke and the Pin in a 76 Differential. I remember seeing it once, but can't find it now. Memory says it is not supposed to be more than .030".
    Any help would be appreciated,
    • 43221
    Re: Rear Yoke Clearance
    Bob-----
    There is no GM spec on it. However, I usually only recommend about 1/16". 0.030" would be at the absolute limit of what I'd consider acceptable. From that point, wear will accelerate rapidly.
    • Bob U.
      • April 30, 2001
      • 21
      Thanks Joe, I am going to replace one that has about .055" clearance.
        • 43221
        Bob-----
        One correction to what I wrote previously. The maximum that I recommend is about 1/16" (or, 0.0625). So, 0.030" is obviously not the "absolute maximum" of what I'd recommend; it's about half that. I don't know what I was thinking when I wrote that----I must have been sleepy.
        Anyway, you're going to be very surprised when you see what the end of the axle with 0.055" clearance looks like when you remove it.
        • Bob U.
          • April 30, 2001
          • 21
          Joe:
          At first I thought I had a lot more than the .055", when I took it apart I found the snap ring for the side with all the movement stuck in one of the Posi springs . I had to 'help' the yoke out of the cage because the end was mushroomed. After cleaning off the mushroom and using a new snap ring, I checked clearance and got the .055". I was going to replace the yoke anyway but then couldn't find the max tolerance to check the other side. I know I have read it somewhere, but couldn't find it again.
          Thanks for your input. You certainly are a great resource for everyone!
          Bob
            • 43221
            Joe:
            Bob
            Bob------
            When you find a yoke axle "mushroomed", that automatically means excessive wear. When wear gets to manifesting itself in this way, the case hardening is worn through. Personally, I would NEVER re-use such an axle, even after removing the "mushrooming".
