1962 F.I. Radiator Seals - NCRS Discussion Boards
  • Jim B.
    • November 1, 1982
    • 10
    In a attempt to put my F.I. car back to original I purchased the high horse radiator seals. Where do they go? I have the two long ones on each side installed. The corner ones and the other long one I can't figure out where they go. Do they go in the top corners and top and if so how do they attach? Or do they go across the bottom? Thanks in advance Jim Benedict (5998)
  • Christopher R.
    • March 31, 1975
    • 1599
    Re: 1962 F.I. Radiator Seals
    The 2 side ones you have already installed are in the back of the AIM - in the options (fuel injection) section.
    The other 3 seals went on all '62s. They're found somewhere in the middle of the AIM - the section that applies to all cars. Those 3 seal the bottom of the radiator frame to the body. The corner ones go in the 2 lower corners. The longer one goes on the bottom. They're glued between the radiator frame and the body of the car.
