56 Chassis Detail - NCRS Discussion Boards
56 Chassis Detail
  • Mark P.
    • July 31, 2003
    • 407
    56 Chassis Detail
    I am getting ready to paint my chassis on my 56 and have noticed from the JG that there are a lot of areas left in question as to what should be painted black and what shoudl be left alone. I know that some items should be left the natural steel or the original plating on the fasteners, but I'm not exactly sure what is supposed to be what.
    Is there another guide out there I can use or do any of you have a list on what finishes should be there? Any help or insight is very much appreciated.
    Mark
    Mark Pugmire
    54 Pennant Blue
    56 Cascade Green Dual Quad
    56 Arctic Blue Dual Quad
    66 Nassau Blue 427 L36 Convertible
    67 Marlboro Maroon L79 Coupe
  • Jerry G.
    • February 1, 1989
    • 228
    Re: 56 Chassis Detail
    I did a body off on my 56 last year Mark. Maybe I can help. Private email sent.
    • Gary C.
      Administrator
      • October 1, 1982
      • 17940
      Mark, if you'll post the particular chassis items you have questions about their finish they will get answered. Gary....
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • Mark P.
        • July 31, 2003
        • 407
        Okay....it's maybe a bit much, but here goes...
        What fasteners are not painted?
        Exhaust fasteners painted?
        Front crossmember bolts painted?
        Front suspension pivot shafts, bushings, seals and associated hardware painted black?
        Rear diff. u-bolts painted? Rear spring bands? Bolts, shackles and bushings?
        Wheel cylinders and other compnents for brakes at the wheel? Wheel backing plates painted that brake shoes, wheel cylinders and other components attach to (inside)?
        Master cylinder? I saw that it could be either black or unpainted?
        3rd arm? Painted as an assembly, including attached components, tie rods and bolts painted?
        Grease zerks patined?
        Park brake linkage on frame and other attachments and fasteners painted?
        Do exhaust pipes and mufflers have a heavy/complete coating of black paint or light?
        Steering relay and associated fasteners painted?
        Bumper mounts front and rear painted black along with fasteners?
        Motor mount to frame bolts painted?
        Fasteners to attach transmission mounts and crossmember painted black?
        Maybe a simpler question would be: What subassemblies are assembled and attached as a unit after painting? That would tell me what fasteners need to be painted and which ones don't.
        See below for items I'm pretty sure on, but feel free to correct me:
        Semi-Gloss Black - Frame
        Semi-Gloss Black - Brake drums
        Semi-Gloss Black - Rear Springs
        Semi-Gloss Black - Front Springs
        Semi-Gloss Black - Shock absorbers
        Semi-Gloss Black - Clutch cross shaft/linkage
        Semi-Gloss Black - Front suspension (main components)
        Semi-Gloss Black - Radiator support (fasteners, too?)
        Semi-Gloss Black - Transmission (including shift rods?)
        Semi-Gloss Black - Driveline
        Semi-Gloss Black - Differential
        Natural steel - Park brake cables/mechanism
        Unpainted - Suspension bumpers
        Unpainted - Suspension fasteners
        Unpainted - Shock mounting fasteners
        Unpainted - Fuel lines
        Unpainted - Brake lines
        Unpainted - Rebound straps
        Cadmium - Stabilizer bar links
        Please tell me where I'm wrong or just help fill in the blanks.
        Thanks, guys.
        Mark Pugmire
        54 Pennant Blue
        • Gary C.
          Administrator
          • October 1, 1982
          • 17940
          Mark,
          First - Richard Brodeur had an article in the Restorer in 2003 about chassis finishes. 56-7 may differ slightly in some cases. My two cents answers worth to your questions are below.
          Gary
          Exhaust fasteners painted? No
          Front crossmember bolts painted? Blackened
          Front suspension pivot shafts, bushings, seals and associated hardware painted black? No
          Rear diff. u-bolts painted? No
          Rear spring bands? No
          Bolts, shackles and bushings? Not painted, fasteners blackened
          Wheel cylinders and other components for brakes at the wheel? No
          Wheel backing plates painted Yes
          Brake shoes, wheel cylinders NoOther components attach to (inside)? No
          Master cylinder? I saw that it could be either black or unpainted? Prefer Natural
          3rd arm? Prefer Natural Finish
          Painted as an assembly, including attached components, tie rods and bolts painted? Yes
          Grease zerks painted? No
          Park brake linkage on frame and other attachments and fasteners painted? No, fasteners blackened
          Do exhaust pipes and mufflers have a heavy/complete coating of black paint or light? Painted but not dripping heavy
          Steering relay BOX? and associated fasteners painted? No, prefer Natural finish on steering box, fasteners blackened
          Bumper mounts Brackets front and rear painted black along with fasteners? Yes, fasteners blackened
          Motor mount to frame bolts painted? Blackened
          Fasteners to attach transmission mounts and crossmember painted black? Yes, fasteners blackened Maybe a simpler question would be: What subassemblies are assembled and attached as a unit after painting? That would tell me what fasteners need to be painted and which ones don't.
          Semi-Gloss Black - Frame Yes
          Semi-Gloss Black - Brake drums No, natural finish
          Semi-Gloss Black - Rear Springs Yes, each individual element, not assembly
          Semi-Gloss Black - Front Springs Yes
          Semi-Gloss Black - Shock absorbers Yes
          Semi-Gloss Black - Clutch cross shaft/linkage Yes
          Semi-Gloss Black - Front suspension (main components) Yes
          Semi-Gloss Black - Radiator support (fasteners, too?) Yes, fasteners blackened
          Semi-Gloss Black - Transmission (including shift rods?) Natural finish
          Semi-Gloss Black - Driveline Driveshaft, Yes
          Semi-Gloss Black - Differential Yes, however some prefer natural
          Natural steel - Park brake cables/mechanism No
          Unpainted - Suspension rubber? bumpers No
          Unpainted - Suspension fasteners Blackened
          Unpainted - Shock mounting fasteners Natural finish on bottom washers and nut, bolts if used are blackened
          Unpainted - Fuel lines Natural
          Unpainted - Brake lines Natural
          Unpainted - Rebound straps Natural
          Cadmium - Stabilizer bar links Yes
          NCRS Texas Chapter
          • Michael H.
            • January 29, 2008
            • 7477
            You'd think by now, with my very limited knowledge of C1's, that I wouldn't get myself in trouble trying to answer questions but.... betcha the brake drums were coated chassis black. (along with a few other misc items)
            Was the clutch cross shaft really painted black? Or did it maybe receive a bit of chassis black during final blackout?
            • Mark P.
              • July 31, 2003
              • 407
              Gary,
              Thanks for the response. What do you mean by blackened on fasteners? Are you talking about a black oxide finish? Is that something you do yourself, because many of the aftermarket individuals fasteners are all zinc or cad plated. Just for clarification, is the transmission black and the shift rods natural? That's the way I read it.
              Also, as far as items on your preferences, will your preferences pass judging (like on the steering box and the diff.)? I guess I'm wondering if it would pass either way. FYI, I far prefer the natural finish if it is a possibility.
              Mark Pugmire
              54 Pennant Blue
                The Saginaw 3-speed transmission is natural cast iron.
                • Gary C.
                  Administrator
                  • October 1, 1982
                  • 17940
                  Mark, transmission is natural as John points out. You can blacken the fasteners yourself with a kit from Caswell or Eastwood. Gary....
                  NCRS Texas Chapter
                  • Mark P.
                    • July 31, 2003
                    • 407
                    Gary,
                    Tons of help...thanks for all of the input. Another question...
                    Front stabilizer bar finish? natural or black. The JG says the front suspension and cross member assembly was "sprayed after assembly, but before mounting to the frame."
                    Mark
                    Mark Pugmire
                    54 Pennant Blue
                    • Gary C.
                      Administrator
                      • October 1, 1982
                      • 17940
                      Mark, the sway bar and brackets are painted. Bolts blackened. Gary....
                      NCRS Texas Chapter
                      • Mark P.
                        • July 31, 2003
                        • 407
                        Gary,
                        I've got the frame soda blasted and ready to paint...now for the right paint. From what I have seen, there are as many recommendations out there as there are different kinds of paint. Do you have a suggestion on what paint to use? I want to get the gloss right since I plan on having it judged, but I also want to avoid the original asphaltic paint if possible. I want something fairly durable, but that looks close enough that I won't get dinged on points too badly. I have heard some claim that Eastwood makes a good paint that is fairly close and will pass muster on judging...any thoughts?
                        Mark
                        Mark Pugmire
                        54 Pennant Blue
                        • Steven B.
                          • June 30, 1982
                          • 4012
                          Gary,
                          Mark
                          Mark, side question; What condition, pitting, etc., was your frame in before soda blasting and how does the frame look after soda blasting (acceptable to you)?
                          Thanks!
                          Steve
                          • Gary C.
                            Administrator
                            • October 1, 1982
                            • 17940
                            Mark, sorry for the slow response was attending the Bend Regional meet. Don't really have a recommendation for you as I've always used flatten Imron on my frames and have good results with it. It's tough and durable. Check the archives and there's been lots of discussions about frame paint in the past. Most of the chassis Judges I know will accept it if it's not glossy and doesn't look like powder coating. Gary....
                            NCRS Texas Chapter
                            • Mark P.
                              • July 31, 2003
                              • 407
                              Kind of weird that I'm responding to my own post, but I've gotten several requests as to how my frame turned out after soda blasting, so I thought I'd post on the results.
                              I was very impressed with the process and the surface metal is very smooth and nice. I've used sand and media blasters and, to varying degrees, they left the surfaces a little rough. I was thrilled to see the frame on the 56 tourn out so nice. It was in pretty good shape anyway, but it was beautiful when finished. FYI, I don't know that I would use the soda process on a heavily rusted frame. I do't think it's agressive enough. JMHO.
                              Perhaps I can post some pictures of the area around the VIN stamp and other areas later today.
                              Thanks for the interest.
                              Mark
                              Mark Pugmire
                              54 Pennant Blue
