62 4-spd reverse lockout linkage - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2415
    All of a sudden the T-handle on the shifter feels like there is no spring tension on it when I pull up to put it in reverse. I can see the little spring while laying on my back under the car. Did something break? Help!
  • Mike M.
    Director Region V
    • August 31, 1994
    • 1463
    Re: 62 4-spd reverse lockout linkage
    If the spring is intact and attached at the bottom, perhaps the lead head retainer in the "T" let go.
    I won't say "HaND", because with this dilemma, you probably will not.
    • Mike E.
      • February 28, 1975
      • 5141
      Most likely the spring itself broke. It then twists down upon itself and provides no tension. I've found hardware store springs and replaced them--you have to cut the head off the peened pin that holds the outer tunnel in which the spring and cable ride--then slide the tunnel up and off. Fix the spring issue--then put a pin back through and peen it.
