Does anyone know the correct antenna cable for a 1957 for NCRS judging purposes or is it even judged? I have 2; one that is in a GM bag with Gr. 9.647, part number 3866077 and has the following markings on the cable in small white lettering: W-519. And the other is not in a bag, so I don't know the exact part number, but is the same length and has the same connections at each end and has the markings: WARD-ANCOA 15-486. Is either of these correct? Also, does the routing for the antenna cable from the antenna mast to the radio following and use the same grommets as the rear wiring harness? That's what the assembly manual appears to show. Anyone know for sure?
Thanks Bill
Thanks Bill
