62 tie-down for towing - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2418
    I will be towing my 62 about 1400 miles from South Texas to Streator, IL on an open trailer. What are the best points to attach hold-down straps on the frame or axle?
  • Art A.
    • June 30, 1984
    • 834
    Re: 62 tie-down for towing
    John definitely on the frame. Check the archives, this subject has been discussed many times.
    • Dan A.
      • May 31, 1974
      • 1073
      I agree with Art that this has been discussed many times. Although I have not found anything specific to the solid axle cars.
      I did post a thread asking for the locations on the car specific to the cars with trunks. Sadly there was no satisfactory response.
      https://www.forums.ncrs.org/showthread.php?t=51614&uid=9423
      • Art A.
        • June 30, 1984
        • 834
        Dan and John, I have not investigated the C-1 tie down locations, BUT I'm sure that they are there......someplace. GM used what is called an "R" hook to transport their cars and trucks to the dealers. The R hooks fit into a slotted hole about 1 inch by 1 1/2 inch. These holes generally have a backing plate inside the frames that can be felt with your pinkie finger. The C-2s are located in the bottom of 3rd cross member............there are two such holes in that location, the one with the downward metal flange is the reinforced one. The fronts are a few inches from the front frame, on the side of the frame rail and are at a slight angle rearward.
        I'm pointing out the C-2 location so you can get an idea where to look on the C-1s.
        I hope this helps
          • 15631
          I have looked at a number of C1 frames, and I have not been able to see a tie-down location. I could easily be missing it, and looking at a bare frame is a lot different than the whole car. I hope some C1 enthusiast will reveal this secret to us.
          • John F.
            • March 23, 2008
            • 2418
            Since no replies, I will be blocking the front/rear tires with 2x4's attached w/drywall screws to the wood deck, and try to cross-tie the rear axle to some D-rings in the deck. Also drive very carefully! If anyone can make it to the "cruiser night" in Streator, IL. I'll see you there.
            • Bruce B.
              • May 31, 1996
              • 2930
              On C1s I like to run straps around the rear differential housing ( be careful to avoid the brake lines) and run the ratchet tiedowns straight back to the tiedown rings.
              On the front put the straps through the lower a-arm and cross the ratchet tiedowns to the tiedown rings.
              I never found a need for wheel blocks.
              • John F.
                • March 23, 2008
                • 2418
                Where on the car are you attaching the front tie-down?
                • Bruce B.
                  • May 31, 1996
                  • 2930
                  John,
                  I loop the strap through the lower a-arm and then attach to the ratchet tiedown. This has worked well for me many times. When towing stop frequently and check the tightness of the 4 tiedowns.
                  • John F.
                    • March 23, 2008
                    • 2418
                    My round trip of 1300+ miles each way went without a problem. The trailer had a wood floor with tie-downs. The tie-downs had an "s"type hook on each end with a ratchet. I cross-tied the rear with one end of the hook in the holes of the rear crossmember and the other end to the tie-down ring and then to the other side. I cross-tied the front with one end attached to outer end of the "A" frame and then other to the tie-down ring. Just for overkill I attached a couple of pieces of 2x4 to the floor with drywall screws to block the front and rear tires.
                    • Gary B.
                      Infrequent User
                      • December 1, 1974
                      • 26
                      Back in 1976, I had my 62 brought back from CA to Ohio by a professional car hauler who moved cars for a well known corvette broker. I assume they put hooks over back edge of the two lower A-arms. I picked up the car, signed the release and a few weeks later discovered that I had two ripped lower a-arms. My loss. Fortunately my good friend in CA had a 54 sedan that was a parts car and I took the opportunity to replace the springs and rebuild the front end. Don't use the lower a-arms for a tie down.
