69 Exhaust Manifold Bottom Studs - NCRS Discussion Boards
  • Craig C.
    • July 31, 1999
    • 53
    I need to get 2 sets of studs for the bottoms of my '69 big block exhaust manifolds. What is the overall length of the stock BB manifold studs? Are they the same length on both sides even though the right side includes the heat riser?
    Thanks in advance,
    Craig
    • 43247
    Re: 69 Exhaust Manifold Bottom Studs
    Thanks in advance,
    Craig
    Craig-----
    No, they are NOT the same length on either side. The left side is 2-9/16"; the right side (heat riser) is 3-1/16". Currently, the left side is GM #14088827 and the right side is GM #14088828. However, I HIGHLY recommend the use of stainless steel studs.
    • Gary B.
      • February 1, 1997
      • 7053
      Exhaust Manifold Bottom Studs; Correct for '66 also
      Joe,
      Are those same GM parts numbers correct for the studs for '66 SB exhaust manifolds?
      Gary
        • 43247
        Re: Exhaust Manifold Bottom Studs; Correct for '66 also
        Originally posted by Gary Beaupre (28818)
        Joe,
        Gary
        Gary-----
        Yes, the same. These are not ORIGINAL part numbers, though. They are at least a "3rd generation" supercession. How they differ from the originals, I do not know.
