Tire dressing recommendation - NCRS Discussion Boards
  • Alan D.
    • January 1, 2005
    • 2038
    Re: Tire dressing recommendation
    My understanding (feedback from a detail shop) is that the dressings like armorall, muguiers, are not great for the tire rubber maybe that's why they brown up.
    The 303 is formulated to protect the rubber from UV and is what I have been using for a decade.
      • 15668
      The "brown" is residual mold release compound. It's not that visible on new tires, but it holds dirt and eventually turns brown. Mineral spirits will remove it, and I thoroughly clean new tires with mineral spirits before mounting them. Scrubbing with soap and water will not remove mold release compound, nor will tire cleaning chemicals like Bleach-White. Once the mold release is removed it's easy to keep the tires clean with soap and water.
      I've been using Armor-All for at least 30 years and have tires that have been in service for 15-20 and never found any evidence that Armor-All is harmful (though I use it spareingly). I think that's just another myth.
      • Dave F.
        • December 1, 2003
        • 508
        That has not been my experience with Meguiars' rubber bumper treatment #42. Use it sparingly and the tires stay black for months w/o the gloss.
        • Jim W.
          • February 1, 1980
          • 324
          Another vote for 303 Aerospace.
          • David D.
            • January 1, 2005
            • 416
            I have to agree.....as well
            • Kurt G.
              • April 30, 2005
              • 343
              Meguiars vinyl and rubber conditioner is great. There is no formaldihyde in it to dry out and rot your rubber like Armorall, STP and most of the others, it doesn't have too much shine, and it protects not only the rubber on your tires, but it is also good on protecting the vinyl on the dash, etc from UV damage. I've used it for many years and have had no problems.
              Kurt Geis
              Chairman, Midway USA Chapter
              Targa Blue 1972, Top Flight and Duntov Award, 2014
              Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
              Arctic White 2013 60th Anniv Special Edition Conv.
              • Alan D.
                • January 1, 2005
                • 2038
                Thanks for tip on the mineral spirits cleaning, picked up another unknown detail. Guess we all have a certain brand.
                • Jeff S.
                  • July 31, 1984
                  • 384
                  Do you know if the use of mineral spirits to remove mold release agent from new tires would likely stain a colored sidewall (white, red or gold) stripe?
                  • Jaime G.
                    • April 1, 1988
                    • 480
                    #24
                    As mentioned above, Its your choice.
                    I prefer a matte natural finish and no silicone.
                    Griots Garage vinyl and rubber dressing is
                    my choice.
                      • 15668
                      #25
                      Originally posted by Jeff Smith (7732)
                      Good question. Removing the mold release compound with mineral spirits/paint thinner is very messy job, and figure the rags are throwaway because they cannot be cleaned.
                      I've never had anything but blackwall tires, so I never had to worry about colored sidewall treatments.
                      Go slowly and try to avoid getting anything on the white letters, but with sufficient wiping with mineral spirts wetted clean rags any dirty residue should eventually come off.
                      You'll need lots of old rags. I use a spray bottle of mineral spirits and old toothbrushes to get into the molded in lettering like the UTQG and size data, and I'd say I have to go over each tire about three times before it's really sufficiently clean and free of the mold release compound, which is really nasty stuff!
                      • Anthony G.
                        • February 1, 2006
                        • 50
                        #26
                        I have found that the Stoner's tire product seems to work OK, as long as you rub a tad to get in all the cracks and eliminate any "over" shine.
                        Tony Gray
                        York, PA
                        66 327/350 Convert.
                        AACA Senior Award Winner Hershey 2009
                        • Steven B.
                          • June 30, 1982
                          • 3989
                          #27
                          The mineral spirits works good! I have used Armor All for decades and also Meuiar's---I now use the satin look, not the wet look. There are alot of good products out there.
                          I do not recommend you do what we did in the 60's----shine 'em with brake fluid!
                          • Gary S.
                            • July 31, 1992
                            • 1632
                            #28
                            I use a 50/50 blend of Armor-All and distilled water - gives a nice black satin finish. I think shiny tires look horrible.
                            This was the comment I heard from a judge during my first ever judging on my 72 years ago. The judge mentioned "see the tires on the car over there?" and then proceeded to tell me that he thought they were too shiny. They were. Almost plastic looking, they were so shiny. I have been using a 50/50 blend ever since then, just as Duke says. Not too shiny, but enoughi to show that you like a well dressed tire.
